Populate Variables - Interlacing
philthewiz
Post by philthewiz »
Hi!
Thank you again for the new v1.0 and the new features!
I had trouble with the Interlacing Analyzer. I wanted to populate the variables to use in a conditional node but the selection in the options of the Interlacing node seems empty after choosing my user value. (See attachment)
The conditional node doesn't seem to get the value either. Am I missing a step?
Let me know if this seems like a bug. Thank you!
Screen Shot 2020-02-18 at 11.32.08 AM.png (56.59 KiB) Viewed 9197 times
Re: Populate Variables - Interlacing
Hello Philthewiz,
You're right, seems to be a bug. Thanks for reporting.
I contact Steinar to report to him.
Hi Philthewiz,
Yes and no, it's not a bug but it is a bug....The node need an integer variable. So if you create one and use that it should be OK. I will try to make the variable types accepted clearer in the nodes.
philthewiz
This is working! Thank you Benjamin and Steinar :)
