SOLVED: Transcoded P2 Files not getting delivered?
nknuelle
Post by nknuelle »
I tried to transcode P2 Structure to AVCIntra100 (with create Avid Project Structure checked) and deliver the processed files to a folder on a network drive.
The workflow is like this:
Monitor(P2 Structure)->AVC Intra100 Encoder->Deliver(Network Path)
The FFAStrans monitor shows that all processing was successful but the folder in the network path is still empty. I double-checked the folder path of the delivery folder but there are no files...
I downloaded the latest 64bit files from the homepage but did not apply the patch as I assume that the patch is already applied to the latest version? I downloaded it yesterday.
Greetings
Re: Transcoded P2 Files not getting delivered?
Hi nknuelle,
Right, so that leaves room for misunderstanding...; The update must be applied to the latest version, which is 1.0.0. Guess we need to make that clearer so thanks for notifying about that! :-)
Anyway, apply the patch and try again.
nknuelle
Post by nknuelle »
No problem for the notification :)
The problem seems to be solved after applying the patch files.
Thank you anyway for this software!
