DVD Encoder Bugs
philipchristiansen
DVD Encoder Bugs
Post by philipchristiansen »
Hey!
Just started really messing around with v1.0, and it looks like there are a couple bugs going on with the DVD encoder.
1. The bitrate setting doesn’t seem to work. Set at 3000kbps, still renders at ~8000kbps. I think this was also a bug back somewhere in v0.9.
2. The DVD encoder doesn’t render out a full frame. Looks like the bottom 1/3 of the frame is missing.
3. Looks like the encoder will hang sometimes and error out.
For #1, looks like it just ignores whatever bitrate is specified in the encoder node.
For #2, I am not sure if this is an issue with FFASTrans or maybe with VLC, where I was viewing the files. On one computer it played back fine, on others it didn't. I might play with this more and see if I can find anything more solid.
For #3, this definitely seems to be related to processor usage and job instances. I tried adjusting the timeout settings in the workflow properties, but that made no difference. If I limit down instances to processes to 1, it works fine. Any additional processes above 1 and it fails. This is the error:
Timeout (0) reached! Node failed due to abnormal inactivity during encoding!
I have attached some source files, encoded files, and a log json from one of the failed files in the Google Drive link below:
https://drive.google.com/open?id=10qUTe ... Azse8VqapA
As an additional note, the encoder seems to be much slower than the last v0.9 release. I can easily process 3 jobs in v0.9 at 5.5-7x, but on the same hardware in v1.0, 2 jobs at 5-6x is all it manages.
Hope all this helps! If I find anything more, I'll add it in here. Can't wait to knock these out of the way to be able to use some of the new features with v1.0!
Re: DVD Encoder Bugs
Hi Phlip,
Thanks for reporting, I will take a look at it.
philipchristiansen
Hey Steinar!
Was wondering if there was any more info you might need on my end.
Happy to help!
Hi philip,
Sorry about the delayed reply but I can confirm that the bit rate does not behave as expected, and it will be fixed. Also, in my tests the speed difference might be tied to same issue, although not the kind of difference you report. After the fix they perform pretty much the same.
The other issue with timeout I'm not so sure about. Is it reproducable?
philipchristiansen
I think it is reproducible?
It seems that it pops up during processing instead of displaying "Waiting for next processor resources..." Instead of just holding the job, it just fails out. If a run only a single job at a time, it works perfectly, but when I spin up multiple jobs on multiple cores and really run, it throws tons of errors.
philipchristiansen
Definitely reproducible. I just spun up a fresh install of Windows 10 just to make sure I hadn't done anything weird in the upgrade process from 0.9, and it's still struggling.
Would it help if I sent you the workflow?
jan2ooo
Post by jan2ooo »
@admin
I have the same problem. The bottom of the image is black :cry: So I would like to try somethin different. I found this script at doom9:
@REM Aspect Ratio (aspect) (4/3 or 16/9 for DVD compatibility)
set E_DAR=4/3
@REM Frame size (s) (b up to 2500 kbps =>s=704x480 (NTSC), b greater than 2500 kbps =>s=720x480 (NTSC))
set E_SZE=720x480
@REM Frame rate (r) (use 25 for PAL, 24000/1001 or 30000/1001 para NTSC)
set E_FPS=24000/1001
@REM DC precision (dc) [8;10] (b up to 1800k =>dc=8, between 1800k and 3500k =>dc=9, greater than 3500k =>dc=10)
set E_DC=9
@REM >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
@REM >>                                    Matrices
@REM MPEG (default matrix for any bitrate)
set E_INTRA=8,16,19,22,26,27,29,34,16,16,22,24,27,29,34,37,19,22,26,27,29,34,34,38,22,22,26,27,29,34,37,40,22,26,27,29,32,35,40,48,26,27,29,32,35,40,48,58,26,27,29,34,38,46,56,69,27,29,35,38,46,56,69,83
set E_INTER=16,17,18,19,20,21,22,23,17,18,19,20,21,22,23,24,18,19,20,21,22,23,24,25,19,20,21,22,23,24,26,27,20,21,22,23,25,26,27,28,21,22,23,24,26,27,28,30,22,23,24,26,27,28,30,31,23,24,25,27,28,30,31,33
@REM MPEG Standard (for any bitrate, the default matrix of FFMPEG, there are matrices better than this)
@REM set E_INTRA=08,16,19,22,26,27,29,34,16,16,22,24,27,29,34,37,19,22,26,27,29,34,34,38,22,22,26,27,29,34,37,40,22,26,27,29,32,35,40,48,26,27,29,32,35,40,48,58,26,27,29,34,38,46,56,69,27,29,35,38,46,56,69,83
@REM set E_INTER=16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16
@REM FOX New Matrix (manolito's suggestion, for bitrate>=3000k)
@REM set E_INTRA=08,08,09,09,10,10,11,11,08,09,09,10,10,11,11,12,09,09,10,10,11,11,12,12,09,10,10,11,11,12,13,13,10,10,11,11,12,13,13,14,10,11,11,12,13,13,14,15,11,11,12,13,13,14,15,15,11,12,12,13,14,15,15,16
@REM set E_INTER=08,08,09,09,10,10,11,11,08,09,09,10,10,11,11,12,09,09,10,10,11,11,12,12,09,10,10,11,11,12,13,13,10,10,11,11,12,13,13,14,10,11,11,12,13,13,14,15,11,11,12,13,13,14,15,15,11,12,12,13,14,15,15,16
@REM FOX Home Entertainment
@REM set E_INTRA=08,08,09,11,13,13,14,17,08,08,11,12,13,14,17,18,09,11,13,13,14,17,17,16,11,11,13,13,13,17,18,20,11,13,13,13,16,17,20,24,13,13,13,16,17,20,24,29,13,12,13,17,19,23,28,34,12,13,17,19,23,28,34,41
@REM set E_INTER=08,08,08,09,09,09,09,10,08,08,09,09,09,09,10,10,08,09,09,09,09,10,10,10,09,09,09,09,10,10,10,10,09,09,09,10,10,10,10,11,09,09,10,10,10,10,11,11,09,10,10,10,10,11,11,11,10,10,10,10,11,11,11,11
@REM FOX1
@REM set E_INTRA=08,08,09,11,13,13,14,17,08,08,11,12,13,14,17,18,09,11,13,13,14,17,17,19,11,11,13,13,14,17,18,20,11,13,13,14,16,17,20,24,13,13,14,16,17,20,24,29,13,13,14,17,19,23,28,34,13,14,17,19,23,28,34,41
@REM FOX2
@REM FOX3
@REM Didée's SixOfNine-HVS (HVS:Human Visual System, for bitrate>=3000k)
@REM set E_INTRA=08,11,12,12,13,15,16,17,11,11,12,12,14,15,16,17,12,12,13,14,15,16,17,18,12,12,14,16,17,18,19,19,13,14,15,17,19,20,20,20,15,15,16,18,20,21,22,22,16,16,17,19,21,22,23,24,17,17,18,19,20,22,24,24
@REM set E_INTER=12,11,12,12,13,14,15,16,11,11,12,12,13,14,14,16,12,12,12,13,14,15,16,17,12,12,13,15,16,17,18,18,13,13,14,16,18,19,19,20,14,14,15,17,19,20,22,22,15,14,16,18,19,22,23,24,16,16,17,18,20,22,24,24
@REM manono1 (the manono's favorite matrix)
@REM set E_INTRA=08,08,08,09,11,13,14,17,08,08,09,11,13,13,14,17,08,08,11,12,13,14,17,94,09,11,13,13,14,17,17,94,11,11,13,13,14,17,94,94,13,13,14,16,17,20,94,94,13,13,14,17,94,94,94,94,13,14,17,94,94,94,94,94
@REM set E_INTER=12,12,13,14,15,16,22,26,12,13,14,15,16,22,26,32,13,14,15,16,22,26,32,41,14,15,16,22,26,32,41,53,15,16,22,26,32,41,53,94,16,22,26,32,41,53,70,94,22,26,32,41,53,70,94,94,26,32,41,53,94,94,94,94
@REM manono2
@REM set E_INTRA=08,12,13,14,15,16,19,22,12,13,14,15,16,19,22,26,13,14,15,16,19,22,26,32,14,15,16,19,22,26,32,41,15,16,19,22,26,32,41,53,16,19,22,26,32,41,53,70,19,22,26,32,41,53,70,94,22,26,32,41,53,70,94,127
@REM set E_INTER=12,12,13,14,15,16,19,22,12,13,14,15,16,19,22,26,13,14,15,16,19,22,26,32,14,15,16,19,22,26,32,41,15,16,19,22,26,32,41,53,16,19,22,26,32,41,53,70,19,22,26,32,41,53,70,94,22,26,32,41,53,70,94,127
@REM manono3 (according to manono, for cases when the movie doesn't compress well at all)
@REM set E_INTRA=08,10,10,12,13,15,16,20,10,10,12,15,17,19,20,20,10,12,15,17,19,20,20,23,12,15,17,19,20,20,25,25,13,17,19,20,23,25,25,27,15,19,20,23,25,27,27,30,16,20,20,25,25,27,30,35,20,20,23,25,27,30,35,45
@REM set E_INTER=12,14,17,18,19,20,24,28,14,16,17,18,19,23,27,32,17,17,18,19,20,27,30,37,18,18,19,20,27,30,35,37,19,19,20,27,30,35,37,40,20,23,27,30,35,37,40,44,24,27,30,35,37,40,40,44,28,32,37,37,40,44,44,48
@REM HVS Best (for low bitrate)
@REM set E_INTRA=08,16,16,16,17,18,21,24,16,16,16,16,17,19,22,25,16,16,17,18,20,22,25,29,16,16,18,21,24,27,31,36,17,17,20,24,30,35,41,47,18,19,22,27,35,44,54,65,21,22,25,31,41,54,70,88,24,25,29,36,47,65,88,115
@REM set E_INTER=18,18,18,18,19,21,23,27,18,18,18,18,19,21,24,29,18,18,19,20,22,24,28,32,18,18,20,24,27,30,35,40,19,19,22,27,33,39,46,53,21,21,24,30,39,50,61,73,23,24,28,35,46,61,79,98,27,29,32,40,53,73,98,129
@REM AVAMAT7 (for low bitrate, also called AUTO-Q2)
@REM set E_INTRA=08,16,19,22,26,28,32,38,16,16,22,24,28,32,38,44,19,22,26,28,32,38,44,48,22,22,26,32,38,44,48,54,22,26,32,38,44,48,54,64,26,32,38,44,48,54,64,74,32,38,44,48,54,64,74,84,38,44,48,54,64,74,84,94
@REM set E_INTER=16,20,24,28,36,42,46,52,20,24,28,36,42,46,52,58,24,28,36,42,46,52,58,62,28,36,42,46,52,58,62,68,36,42,46,52,58,62,68,78,42,46,52,58,62,68,78,88,46,52,58,62,68,78,88,99,52,58,62,68,78,88,99,99
@REM >>                                   FFMPEG CLI
ECHO.---------------------------------------------------------------
ECHO.First pass ...
ffmpeg.exe -i %E_SRC% -pass 1 -passlogfile Pass.log -vcodec mpeg2video -maxrate %VBV_MBR% -bufsize %VBV_MBS% -g %E_MIK% -bf %E_MBF% -bidir_refine 0 -b_strategy %E_ABF% -brd_scale %E_SBF% -b_sensitivity %E_DBF% -dc %E_DC% -q:v %E_FQ% -intra_vlc true -intra_matrix %E_INTRA% -inter_matrix %E_INTER% -an -f mpeg2video -y NUL
ECHO.Second pass ...
ffmpeg.exe -i %E_SRC% -pass 2 -passlogfile Pass.log -vcodec mpeg2video -b:v %E_BR% -maxrate %VBV_MBR% -bufsize %VBV_MBS% -g %E_MIK% -bf %E_MBF% -bidir_refine 0 -sc_threshold %E_TSD% -b_sensitivity %E_DBF% -me_range %E_RME% -mpv_flags mv0+naq -mv0_threshold 0 -mbd %E_RDO% -mbcmp %E_CMB% -precmp %E_CMP% -subcmp %E_CMP% -cmp %E_CMP% -skip_cmp %E_CMS% -dia_size %E_DIA% -pre_dia_size %E_DIA% -last_pred %E_AMP% -dc %E_DC% -lmin %E_MLM% -mblmin %E_MBL% -qmin %E_MQ% -qcomp %E_VQ% -intra_vlc true -intra_matrix %E_INTRA% -inter_matrix %E_INTER% -f mpeg2video -color_primaries 5 -color_trc 5 -colorspace 5 -color_range 1 -aspect %E_DAR% -y %E_VID%
IF EXIST "Pass*.log" DEL "Pass*.log"
@pause
@REM THE END
Is it possible to transfer it to FFAStrans command executor node somehow?
@jan2ooo
i guess i would use a write text processor, paste the script you posted, replace all spots of interest with ffastrans variables and in the workflow, after writing the bat file to %s_job_work% folder, execute the batch with a cmd processor.
Lots of work for nothing in my mind. It would be far better if we could locate the source of the issue. Can you tell me how i can reproduce it?
Just submitted some 16x9 file to the dvd enc but had no problems with it.
jan2ooo
Post by jan2ooo »
Sounds complicated :lol: Thanks you.
I have no clou why this happens. I have a Watch Folder and the DVD processor, thats all. But as I read it in one of the posts: maybe it's a VLC issue? I will test it again with another player.
@jan2ooo
such problem sounds very much like that i need the exact same source file format as you have to reproduce the problem, maybe you find a small file that causes the same error and can share it with us?
