Decoding audio to original bit depth
Pogle
Post by Pogle »
is it possible to implement audio decoding to the original bit depth via the A/V Media- Decoder?
Currently only 16 bit are used. All of our archived files have 24 bit audio and I have to keep this resolution. Extracting the audio initially via Encoding node and merging it again with the processed video (new duration) is quite complicated (for me). It would be much easier to choose between 16/24/32 bit or orig. bit depth in the A/V Media Decoder, wouldn't it?
regards
-Pogle-
Re: Decoding audio to original bit depth
Hi Pogle, thank you for using FFAStrans and welcome to the forum! :-)
You are absolutely right. We need higher bit depths in the decoder so this will be implemented as soon as possible and probably available in the next feature update. Thanks for notifying! :-)
