1.0.0.4 | Distributing Input-Files To All Available Hosts
Post by taner »
Hi Admin-Team,
I'm not sure whether it is a bug.
(Manually) submitted Files are not distributed to all available hosts.
Best
Taner
Re: 1.0.0.4 | Distributing Input-Files To All Available Hosts
Hello taner,
I just test it and you're right, same think for me only 1 host takes all files. I will see with Steinar.
Thanks for reporting.
Hi Taner and Ben,
I'm not able to reproduce this. I have tried with two different farms and they behave the exact same way:
Jobs are "evenly" distributed among the available hosts. But this CAN vary, depending on the number of jobs and the available job slots per host. For example; If you submit 3 jobs and you have a host that has 3 available job slots, it can, depending on where in the job chekcing cycle it is, take all jobs. But if you for example send 6 jobs and you have 3 servers set to take 2 jobs each, the jobs should be evenly distributed.
That said/written, the way jobs are "distributed" probably has some potential of improvements. However, due to the "no-master" design of FFAStrans, perfectly distributed jobs can never be 100% guaranteed.
Hi guys,
Ok, after several trie (with 1.0.0.4), all seems ok. Tests with 2 hosts :
- default -> files processed by the 2 hosts
- all hosts includes -> files processed by the 2 hosts
- all hosts excludes -> nothing happens
- 1 host exclude -> files processed by other host
- 1 host include -> files processed by the selected host.
So, first sorry Steinar for my first post, I was wrong. Then, Taner, you have to check if your farm is ok. Check the firewall settings for example.
Hope you find the issue.
Post by taner »
Hello Steinar,
I've sent you a Private Message.
Best
Taner
Hi Taner,
You are right, and I have found the cause of this behavior. However, it's not a bug but a design flaw related to not having shared work cache. So thanks for notifying and it will be addressed in the next bugfix update! :-)
Post by taner »
