Folder Inside Folder
Post by taner »
Hi Admin-Team,
it would be great having the possibility to create a folder within a folder.
For myself it would help to organize the big amount of workflows I have in a more structured way.
It's definitely more a nice-to-have-thing.
By the way: version 1.0.0.4 is overall great! Much more responsive and very nice enhancements. Thanks all for your continuos efforts!
Best
Taner
Re: Folder Inside Folder
Hello Taner,
It is really easy to create a folder inside another with a command executor (MD command). You can also use a FFAStrans variable to name this folder.
For example: Most of my files contains a date in the name. I fetch this date and use the "week of the year" variable to create a new folder or to deliver to an existing folder. This way my files are sorted by week.
cheers.
EDIT: Sorry Taner, I was wrong... :oops: You speak about FFASTrans workflow manager folder's, not file system folder...So sorry
But you are right, it will be a good idea.
Hi Taner,
It's on the list of new features that would be as you write "nice-to-have". However, as this does not have very high priority I can't tell when you will see this feature.
Post by taner »
