Function: $between | Quotation Marks
Post by taner »
Hello FFAStrans-community,
Maybe someone could help me.
When using function $between I'm not able to extract the part I want.
This is the original string:
input_i" : "-24.11"
I want to extract this:
-24.11
This is the command I use in Populate Variables
$between("VARIABLE", "input_i" : "", """)
As far as I can see it is related to the quotation marks which the original-string has.
Command works when I use an other part which does not have quotation marks.
Does someone know a workaround?
Best
Taner
Re: Function: $between | Quotation Marks
Hey @taner
always good to read from you here!
Good question i updated the Wiki functions section (Escaping doublequotes).
Basically you just need to provide 2 doblequotes instead of one. This works for me using your input:
$between("%s_your_variable%",": ""","""")
or a little more complex, add additionally the input_i... section:
$between("%s_file_list%","input_i"" : ""","""")
Post by taner »
Thanks a lot, it works.
Actually a pretty noob-question.
Didn't have to escape special characters/quotation marks for a long time.
Again: Thanks!
Taner
