Youtube processor issue [SOLVED]
crispyjones
Post by crispyjones »
Noticed a possible bug when this vimeo URL was submitted. It seemed odd that the next MXF processor could not deal with a mp4 or mkv that usually gets downloaded by youtube-dl. I built a test workflow with a branch that copied the direct output of the Youtube processor, instead of media it output another URL file. There was *not* an error on the youtube process, the MXF encoder block tried to treat the new .url file as media and that is where the workflow failed. When I take that same URL and run "youtube-dl.exe https://vimeo.com/412284840" it downloads media without issue.
Re: Youtube processor issue
Hi crispyjones,
This bug is already fixed in the upcoming 1.0.0.5 bug fix release. Stay tuned.
crispyjones
Re: Youtube processor issue [SOLVED]
The upgrade to 1.0.0.5 fixed this issue. Thank you.
