Not denying folders with spaces
c0ntact0
Post by c0ntact0 »
HI everyone,
"Deny Folders" option on monitor folders processor it's not denying folders with spaces in the name, like "Avid MediaFiles".
There is some workaround for this problem?
Rui
Re: Not denying folders with spaces
Hi Rui, thank you for using FFAStrans and welcome to the forum! :-)
I'm not able to recreate. Could you please export and post your workflow, or supply a screen shot of the monitor node?
c0ntact0
Post by c0ntact0 »
Hi, follow a screen shot.
Captura de ecrã 2020-04-28, às 20.43.36.png (165.08 KiB) Viewed 10454 times
I'm still struggling to recreate the problem. I've used the same settings on my network share and it behaves exactly as it should. Files inside the deny folders are not being picked up. If I remove one of the from the list, FFAStrans will pick them up. Can you please double check for typos etc. in your folders?
c0ntact0
Post by c0ntact0 »
I have created a new workflow and I notice that folders without spaces are failing to be denied too. I'm using the new x64 version, in all my old workflows the "Deny folders" function it's not working. My storage it's a Avid Nexis shared storage:
In the property "folder": "\\\\NEXPLR\\TESTE\\New_folder",
- NEXPLR it's the Nexis hostname
- TESTE it's a Nexis workspace
- New_folder it's a folder in the TESTE workspace root
- I'm sending files to a folder named New_folder inside the folder \\NEXPLR\TESTE\New_folder
Follows a screen shot of my "About" box and the new workflow (json file).
Captura de ecrã 2020-04-30, às 14.05.25.png (151.13 KiB) Viewed 10431 times
TESTE_NEW.json
(5.06 KiB) Downloaded 608 times
Ok so you're a bit behind on the versions. Can you please update to the latest 1.0.0.4 bug fix release? The issue was fixed in the 1.0.0.1 bug fix release.
http://www.ffastrans.com/download/FFASt ... 4_patch.7z
c0ntact0
Post by c0ntact0 »
Hi Steinar, problem solved. Thank you!
But I get this warnings from Windows Defender. I hope they are false positives.
The following error occurred: Error code 0x8007052e. The user name or password is incorrect.
Category: Trojan
Description: This program is dangerous and executes commands from an attacker.
Recommended action: Remove this software immediately.
Items:
x86\FFAStrans.exe
Get more information about this item online.
Category: Trojan
Items:
FFAStrans1.0.0.4_patch.7z
Yes, they're false positives. Very common I'm afraid and we struggle with those all the time :-(
