1.0.0.4 | Avid DNxHR | OP-Atom | No Videofile
Post by taner »
Hello Steinar,
I'm facing the issue that when using Avid DNxHR-Node with activated "Create Avid project structure" the outcome does not produce a videofile but only audiofiles.
If I look at the mediacache-workfolder the OP1a-file which is created during the process seems not to be properly demuxed.
Best
Taner
Re: 1.0.0.4 | Avid DNxHR | OP-Atom | No Videofile
Hello Taner,
Unfortunately it is normal...:( This feature has been temporarily disabled because the compatibility is not reliable.
Disabled since 1.0.0.3 version. You can see that at the FFAStrans's home page :
"The Avid project in the "DNxHR" has been temporarily disabled until underlaying issue with creating compatible files has been fixed."
Steinar could tell you more about that.
Post by taner »
Thanks for the info !
Post by taner »
Are there any chances that DNxHR OP-Atom might have a comeback?
Best
Taner
Hi Taner,
I'm sorry but it does not seem to be any movement on this topic. I wonder if it has been abandonen:
https://github.com/Phygon/bmxlib-bmx/tree/DNXHR
Maybe the original creator of the branch can shed some light. But I asked him on the BMX forum about it almost two years ago but have yet to receive a reply:
https://sourceforge.net/p/bmxlib/discus ... e259/#f585
Maybe you can poke him as well?
