Command executor output to delivery folder
llittleton
Post by llittleton »
I am using a command executor to do a gpu conversion:
%comspec% /c "D:\NVEncC_5.11_x64\NVEncC64.exe -i "%s_source%" --vpp-select-every 2 --fps 60000/1001 -c hevc --cbr 20000 --cu-max 32 --bframes 0 --ref 4 --gop-len 30 --lookahead 15 --strict-gop --profile main10 --output-depth 10 --audio-codec aac --vpp-edgelevel --vpp-deband --video-tag hvc1 --cuda-schedule auto -o "%s_original_path%\%s_original_name%_NVEncC_UHD.mp4""
Is there a way to have to output go to a delivery folder instead?
Thank you,
Lawrence
Re: Command executor output to delivery folder
hey Lawrence,
sure you can do this, it depends a little if you need to calculate your delivery folder or it is always the same,
e.g. change this
to this:
"\\server\share\folder\%s_original_name%_NVEncC_UHD.mp4"
llittleton
emcodem,
Thank you for your reply. What i mean is can i take the output of a command execute node and pipe it into a delivery folder node, and then use the delivery folder node to specify the location and name of the output file?
Thank you,
Lawrence
Understood, so what you do in this case is in the command executor node, check the "set %s_sourcce%" checkbox and enter the name of the produced file, e.g. just this:
This checkbox will tell the "delivery" (and all other subsequent nodes) that they shallw work with the provided file name
llittleton
emcodem,
this solution works perfectly.
thank you.
So nice for stepping by and saying thanks, really appreciated!
