ERROR: Plugin Not Found
Hi there,
never had this before:
I imported this workflow from another PC:
DPX-test-1.json
(16.98 KiB) Downloaded 896 times
and it should be reported, the message says...
I cannot say if the workflow works, I have to work it over again as some .BAT-files are not in place.
so long,
cheers
tom
Re: ERROR: Plugin Not Found
Hi Tom,
You're probably missing the "Files Delete" plugin. You can download it here:
http://www.ffastrans.com/wiki/doku.php? ... processors
Hey Steinar,
thanks - this helps a lot.
regards
tom
