I just stumbled over the GitHub-page from Cyan4973, developer of xxHash which is implemented in FFAStrans. I am wondering if there are any issues using xxHash in Version "xxh3" as described on https://github.com/Cyan4973/xxHash/releases/tag/v0.8.0 .
it says:
What does this mean? are the Hashes generated so far not compatible or comparable over Time and systems? As of now I only to xxHash from single-Machines which are comparing copied files from one machine to a NAS. this works, but will a different machine using xxHash in the future come to the same result? The xxHashes are written to a .JSON-log and so they are usable for future reference.From now on, output values produced by XXH3 for a given input and parameter set will remain identical across systems and across future versions. It makes it possible to store these values for later comparison, or to exchange them across network connections
Furthermore, is xxh3 compatible to the FFAStrans-builtIn-xxHash?
Thanks in advance for clearing things up,
regards
tom
