Hi. I'm running FFAStrans as a windows service. When I run a workflow through files on the computer itself it works great. Also when I don't run FFAStrans as a service it can run a workflow on the Synology NAS that's plugged in through the local network. However, when it's running as a windows service I get the following error:
No such file or directory\r\n",
"code": 4,
"msg": "No video or audio found in media."
I've attached both the log file and the workflow called LT to Proxy. I've also attached a screenshot showing that it's running as a windows service with a Log On.
I can definitely access the NAS storage on the computer that is running FFASTrans.
Any help on getting this resolved would be greatly appreciated.
Thanks,
Ben
No video or audio found in media error when transcoding video from Synology NAS
- FFAStrans as a service.jpg (119.15 KiB) Viewed 7044 times
- LT to Proxy.json
- (3.33 KiB) Downloaded 727 times
- 20200923-1652-5606-2442-68f10cbc98bd.json
- (14.09 KiB) Downloaded 661 times
Re: No video or audio found in media error when transcoding video from Synology NAS
Hey @Ben
thats easy: only you as logged in user can see a mapped network drive using a drive letter "T:". On windows we have to use full UNC paths instead like \\server\share\file.mxf
Hey @emcodem
Oh I see. Thanks so much! It's working perfectly now that I've changed it to \\DiskStation instead of "T:"
