I installed 1.1.0 and copied over my configs from 1.0.4.
I get this error when starting a workflow:
Line 3806 (File "D\FFAStrans1.10\processordef_runner.a3x"):
Error: Variable must be of type "Object".
reverted back to 1.0.4.
Let me know how I can help to get past this issue.
L
1.1.0 error when starting workflow
Re: 1.1.0 error when starting workflow
Hi llittleton,
Thanks for reporting the bug. It has been identified and fixed. A patch will be released later today or early tomorrow. Luckily, this bug is farily easy to work around. Just reinstall 1.1.0 and when starting the FFAStrans Manager, open a node where you can create a user static.
Please consult the wiki for how to: http://www.ffastrans.com/wiki/doku.php? ... _variables
When you have done so, exit FFAStrans and start again.
Sorry for the inconvienience!
Hi llittleton,
Bugfix version 1.1.0.1 is now released. Can you please try an upgrade again?
https://github.com/steipal/FFAStrans-Pu ... 1.1.0.1.7z
issue still present with this fix.
Morover extracted folder is labelled FFAStrans1.1.0 under FFAStrans1.1.0.1.
br,
Jerrysub
br,
Jerrysub
Hi Jerrysub,
I'm sorry but this was a very sad and stupid mistake
The new 1.1.0.1 package contained one wrong file. It's now updated to 1.1.0.2 which SHOULD have the correct file.
it is fixed with this new version.
great
Jerrysub
great
Jerrysub
