I have a command execute node that runs an external exe for transcoding. If I abort a job, the exe continues to run. Is there a way to have the exe
quit when I abort the job?
Thank you
command execute abort job issue
Re: command execute abort job issue
Hi llittleton,
What version are you running? This issue has been adressed in the new 1.1.0 release.
llittleton
Steinar,
Moved from 1.04 to 1.1.02 and this issue is resolved.
Thank you
Thank you
