No conversion on muted (no-audio)-files
Hey there,
anyone experienced this?
I Try to precess uncompressed-MOV-Files to ProRes. When audio is present, the workflow is fine. When there is no audio (audio-channels = 0) the Process says "success" but nothing is converted. The first node is an ProRes AW/KS-Node set to Audio-channels SameAsSource. The coding starts and ends with "success", but no output is generated...
I attached the log of one of this clips. maybe someone can figure out, what was going wrong there. I tried to find a clue in this log, but... you kno... :oops:
thanks in advance,
cheers
tom
20210113-1538-0057-5f8e-d7aa8d785538.json
(733.97 KiB) Downloaded 729 times
Re: No conversion on muted (no-audio)-files
Hi ThomasM :-)
The log indicates that the prores file was created but not delivered. The reason is because you have set the next node "Deliver PK Mono" to execute on fail. But the prores node does not fail and so naturally the workflow ends right after encoding, without delivering anything ;-)
@Steinar
oh no - what a week. Sorry. Many things went wrong here the last days.
Anyway - a big THANK YOU for everything...
regards
tom
Test - do not reply
