Hi there,
strange thing: I am working on this workflow:
but when i try to submit files to the FOLDER-node nothing happens.
I tried it on several machines (WIN10pro Version 20H2). I also excluded FFAStrans-folder from VirusDetection. Anyway - other Workflows are running without problem.
What did I miss?
thanks in advance,
Thomas
workflow wont start
Re: workflow wont start
Hi Thomas,
Check workflow properties->Farming->Include Hosts.
How i found out:
Processors\db\cache\tickets\pending --> Tickets are there but they also STAY in Pending
FFAStrans\Processors\db\cache\exe_log\ --> This is the log file of exe_manager who is responsible for picking up tickets from pending, it says
How i found out:
exclude workflow with id: "20210119-1034-0588-652d-ddd675ebf9ff" from this host.
thank you so much...
Yes - I copied the Workflow from another machine... That´s why...
Great tip with the Tickets-folder. I will have a closer look at that now!
Thanks for your support,
all the best,
tom
all the best,
tom
