NDI SpeedHQ
shaharb
NDI SpeedHQ
Post by shaharb »
Hi!
im pretty new in this area, trying to find my way here :)
im trying to encode to SHQ7 in an .AVI wrapper to use on a NDI desk with alpha.
i cant find a way to decode to AVI what so ever.
can this be achieve with the costume ffmpeg encoder?
anywhere i can find an example of how to use it?
thank you very much!
and thanks for a great software!
Shahar
Re: NDI SpeedHQ
Hey shaharb,
I was not aware that ffmpeg supports SHQ, interesting.
Unfortunately there is nothing built in for you so you have 2 options:
1) commandline executor
2) custom ffmpeg
For using custom ffmpeg, the Input "FFmpeg options:" must be filled with exactly the same that you would give ffmpeg on a commandline except the -i portion and the output.
E.g. if you can produce your output using ffmpeg on commandline, and your command looks like this:
ffmpeg -i c:\temp\input.ext -c:v yourcodec -b:v 100M -map 0 -sn youroutputfile.avi
You would copy the bold part of the command into the FFmpeg options field.
When using a commandline processor instead, you do like this:
cmd /C ""%s_ffmpeg%" -i "%s_source%" -c:v yourcodec -b:v bitrate "c:\path_to\output.avi""
shaharb
Re: NDI SpeedHQ
Post by shaharb »
Thanks emcodem!
I tried to look for information about it - i think i saw a post on newtek site from 2017 claiming that ffmpeg now supports ndi codecs.
but i might have missed the part about it being only the decoder not the encoder. :(
thanks for the example! ill give it a try!
Re: NDI SpeedHQ
Nono you didnt miss anything, it is there
ffmpeg --help encoder=speedhq
The outputted shq version seems to just depend on the pix_fmt, e.g. -pix_fmt yuva444p10le seems to produce SHQ4
shaharb
Re: NDI SpeedHQ
Post by shaharb »
amazing! testing it now :)
thank you!
