Mouse wheel doesn't work as zoom control in FFAStrans 1.2.0 Workflow Canvas pane in WS2012
Silicon
Post by Silicon »
Dear developers
I have noticed another small issue in FFAStrans 1.2.0: the mouse wheel doesn't work as zoom control in Workflow Canvas pane.
How to reproduce the issue:
1. Start FFAStrans app
2. Click to Workflow Canvas pane (i.e. do not select other workflow from Workflow Manager Menu tree)
3. Test the mouse wheel - it works as expected, i.e. acts as zoom control in Workflow Canvas pane
4. Select another workflow from Workflow Manager Menu tree and the click to Workflow Canvas pane
5. Test the mouse wheel - it doesn't work as zoom control in Workflow Canvas pane, but still as scroll control in Workflow Manager Menu tree
Tested via RDP in following OSes:
- the issue occurs in Windows Server 2012 R2 (and Windows Server 2008 R2 SP2)
- in Windows 10 the mouse wheel works correctly.
Thanks for advice.
BR,
Silicon
FFAStrans 1.3.0.2; WebInterface 1.3.0.0
Manager: VM: 2x Xeon E5-2630v3@2.4GHz, 8GB RAM
Workers: 3x HP DL360 G9 (2x Xeon E5-2643v3@3.4GHz,16GB RAM, nVidia M2000)+ 2x Lenovo SR665 (2x AMD EPYC730216C@3.0GHz,128GB RAM, nVidia P2200)
Re: Mouse wheel doesn't work as zoom control in FFAStrans 1.2.0 Workflow Canvas pane in WS2012
Hi Silicon,
Yes, I'm able to recreate the issue. Thanks for reporting! :-)
Silicon
Post by Silicon »
Hello dev team
I can confirm that this issue is fixed in version 1.2.1.
Thanks for that!
BR,
Silicon
