Hey Everyone,
we have just recently updated to version 1.2.0.0.
Now whenever I click on a "populate variables" processor I get this Autolt Error und the application exits:
Line 55334 (File "\\server\share\transcoding\ffastrans\application\FFAStrans.exe"):
Error: Variable must be of type "Object".
Does anyone know what this could be?
Autolt Error Line 55334
Re: Autolt Error Line 55334
Hi Kris,
could you upload an affected workflow please?
Hey!
I just copied the processor from another workflow, where the problem didn't occur and now it works.
Maybe the processor went corrupt during the update.
Well, let's assume this was a hickup
I forgot to say:
Welcome to the forum and thank you for using FFAStrans!
I forgot to say:
Hi Kris,
Even though I have located the bug it would be nice to see the workflow where you had the problem. Hopefully you have it in your archive?
Just right click on the workflow and select "Archive...". Then select the workflow (with date stamp) that likely have populate node with the error. Then export it and send. After that you can revert to your newest version again by going back to the archive and select the latest saved version.
Thanks for reporting!
Hey Steinar,
sorry for the late reply, here is the file.
And thanks for the welcome!!
Regards
Kris
Regards
Kris
- Transcoding Beta_Postprocessing TC Burn-In.json
- (27.89 KiB) Downloaded 582 times
