[Solved]AutoIt Error (34589)
Wahyu
Post by Wahyu »
Dear All,
i want to ask, why is an error ???
Thanks for your help
Re: AutoIt Error (34589)
In your folder I see FFAStrans 1.0.0
Is it just a legacy folder name or are you actually running v1.0? And if you are, what's holding you back from upgrading to 1.2?
Hi Wahyu,
As FranceBB writes, from the looks of the error message it seems you are on an older version and the line the error is referring to has been fixed in 1.2. So please upgrade and try again. Thanks :-)
Wahyu
Post by Wahyu »
yes, I'm still using version 1.0. I haven't switched to 1.2 because I think there are a lot of big changes I need to configure again, but if the error goes away in 1.2 I'll switch to 1.2.
thanks FranceBB & steinar for helping
Just to be sure, backup your workflows and then update. Workflows will be backwards compatible anyway and all the built in nodes will keep working. You will also be able to use additional nodes like Safe Color Limiter, Linear Transformation etc. As to the ones you already have, plenty of bugs have been fixed and the filter builder got smarter so that it's now also able to recognise HDR inputs and tonemap to SDR correctly. I mean, 1.2 is very stable and backward compatibility with your workflows is not gonna be a problem. We really don't see any reason not to upgrade and believe me you won't regret it. We've put so much effort in getting things working smoothly for you guys, it would be a shame if you don't use them. :)
