Keyframes
mrazik
Keyframes
Post by mrazik »
Hi everyone,
have you tried to generate keyframes (scene changes) with the H264/ffmpeg?
I'm struggling with the:
- scene change FFmpeg command
- custom filename
- list of generated jpg files
I'll be glad for any help!
Many thanks,
Mrazik
FFAStrans 1.2.2
Webinterface 1.2.0.4
8.00 GB RAM
NVIDIA Quadro K620
256GB SSD
1GB NIC
Windows 10 Pro 64b
Re: Keyframes
Hey mrazik,
What exactly are you trying to get done and where is your problem?
Here some command that i used in the past. the output files will be named like thumbs_FRAMENUM.png.
ffmpeg -i F:\temp\608.mxf -vf  "select=gt(scene\,0.1), scale=640:360" -vsync vfr -frame_pts 1 "c:\temp\thumbs_%d.png"
mrazik
Re: Keyframes
Post by mrazik »
Hi @emcodem,
thank you for your reply, I'm trying to get generated thumb filenames in the shape "thumb_timecode-of-the-frame.png".
So far without any luck.....
The only thing I can manage is the txt file with generated files, as I can put it as the "Command executor" processor with custom cmd.
Many thanks,
mrazik
FFAStrans 1.2.2
8.00 GB RAM
NVIDIA Quadro K620
256GB SSD
1GB NIC
Windows 10 Pro 64b
Re: Keyframes
Hey,
ok, so let's split up the problems:
1) how to make ffmpeg write the timecode of the frame into the output filename. There are at the best of my knowledge 2 options for this (i might be wrong, better as ffmpeg-user chat):
a) for live recordings we can use
-strftime 1 "c:\temp\prefix_%Y-%m-%d_%H-%M-%S.jpg"
b) for non live we can only put the frame number starting from 0 into the filename
2) the generated filenames to a text file. There are many options for that but not from inside ffmpeg itself.
a) use a batch file after transcode with dir /s /b or such, but i think you already do something like it
b) grep the generated filenames directly from ffmpeg but this is really more simple. Potentially you could add something like:
-loglevel debug 2>&1|findstr Opening 2>&1 > c:\temp\list.txt
In that case c:\temp\list.txt would contain the list of generated files but with some unneccessary stuff around like:
[image2 @ 000001b281e65600] Opening 'c:\temp\thumbs_148.png' for writing
Which doesnt really make your life easier than having a batch as you do now.
Note that the requirement to put the "video timecode" into the filename of extracted images is not really a valid solution as the TC of files can wrap over at 24:00, starting from 0 again which would make ffmpeg potentially overwrite some of the exported images, so it is in general not a valid solution to work with the "video timecode" for filenames when extracting thumbs.
mrazik
Re: Keyframes
Post by mrazik »
Hi @emcodem,
thank you very much, I was trying to get the frame number directly in the thumbnail filename.
So what I found out this is not possible to achieve in FFmpeg nodes, so I used command executor node with cmd:
%comspec% /C "%s_ffmpegx64% -threads 1 -y -i "%s_original_full%" -vf "select=key,scale=320:-1" -an -vsync 0 -frame_pts 1 "%S_KEYFRAME_PATH%\%s_original_name%\%10d.jpg""
Anyway, thank you!
mrazik
FFAStrans 1.2.2
8.00 GB RAM
NVIDIA Quadro K620
256GB SSD
1GB NIC
Windows 10 Pro 64b
Re: Keyframes
Thnks for letting us know :-)
