Upgrading from 1.1 to 1.2 instructions
Ghtais
Post by Ghtais »
Hi guys
I have searched but I can not found any instructions to upgrade from 1.1 to 1.2 without loosing any workflow or settings.
Should I have to copy the 1.1 Db folder in the new 1.2.0 folder to get back my settings and log ? Knowing that I run FFAstrans as a windows service.
Do you have some advices or tips ?
Thank you
Re: Upgrading from 1.1 to 1.2 instructions
Hi ghtais,
The Procedere is the same as here: https://ffastrans.com/wiki/doku.php?id= ... _procedure
You will just not get a popup about upgrading the DB but the steps that you actively do are exactly the same.
In short: stop Services on All hosts, Backup your current prod instance, the Full ffastrans folder, then just extract the files from the New Version into the productive folder, overwriting all files.
Ghtais
Post by Ghtais »
Hi Emcodem
Thank you, I missed this wiki page.
Have a good day :)
