Hi Admin-Team,
I'm not sure if it is a bug.
When I read out the start timecode of an av-file via start tc-variable I get wrong results.
I tried it with several files.
Original start tc is: 01:00:00:00
Read-out value is: 00:00:00:00
Just a quick info.
I haven't had the time to make further tests.
I'm using the latest FFAStrans-version.
Best
Taner
Variable | Start TC | Wrong Result
Re: Variable | Start TC | Wrong Result
Hi Taner,
Can you please share either a short example file or the job log from one of the job showing the issue? In the inbuilt status monitor right click on a job and select "Open log folder...", zip the content and send it so I can investigate. If not, please upload a sample file to http://ffastrans.com/share
Hi Taner,
As Steinar said, please give us more informations cause I tested and it was ok for me with the latest version.
thanks.
thanks.
I think it should depend what kind of file you transcode.
I'am using this variable with a tone of different files and codec and I had no issue with it.
Thanks for your suggestions guys!
I‘ve sent Steinar all relevant files.
Hi Taner,
Thanks for the file. It's nothing wrong with your file so you found a bug in FFAStrans. It's fixed for the upcoming 1.2.1 version.
Thanks for reporting!
