ImageMagick currently has 3 data types (8bit, 16bit, 16git HDR) and both x32 and x64 builds.
Which is used in FFAStrans?
which ImageMagick build is used?
Re: which ImageMagick build is used?
Hey there,
The question kind of don't work for me to be honest (or i don't understand what you are after).
So we use convert.exe in the stills decoder and the watermark node and dcraw.exe in the stills decoder in case you check the "extract from raw" box.
convert.exe is called without parameters, dcraw is called with the -e parameter (Extract embedded thumbnail image).
Can you maybe hint me on what you are after?
Ah, sorry only read the question but not the title
Here is the build info from our used convert.exe, so it is the HDR build version.
Version: ImageMagick 7.0.7-27 Q16 x86 2018-03-18 http://www.imagemagick.org
Copyright: Copyright (C) 1999-2015 ImageMagick Studio LLC
License: http://www.imagemagick.org/script/license.php
Visual C++: 180040629
Features: Cipher DPC HDRIemcodem, wrapping since 2009 you got the rhyme?
