H.264 Encoder PCM Option
crazytiger
Post by crazytiger »
Hi all!
Thanks again for a great piece of kit.
And thanks for the inclusion of PCM as an option in H.264 Encoder.
However, when I try and save this workflow, it seems to revert back to AAC everytime?
I can see in the workflow json it says its pcm, but the workflow when opened in the GUI reverts to AAC.
Is it just me? Or is there somehting I am missing.
Many thanks,
Re: H.264 Encoder PCM Option
Hey there!
no it's not just you, it is a little bug, interesting for @admin to fix if it isn't already fixed :D
Thanks for reporting!
crazytiger
Cool! No problem, thanks for confirming.
Hi crazytiger,
It will be fixed for 1.2.2. Thanks for reporting! :-)
Silicon
Post by Silicon »
Hi @admin and @crazytiger
I have noticed similar small flaw in the same H.264 options dialog: if you choose "fast" in Quality/Speed drop-down menu, it will always revert to "faster".
BR,
Silicon
FFAStrans 1.3.0.2; WebInterface 1.3.0.0
Manager: VM: 2x Xeon E5-2630v3@2.4GHz, 8GB RAM
Workers: 3x HP DL360 G9 (2x Xeon E5-2643v3@3.4GHz,16GB RAM, nVidia M2000)+ 2x Lenovo SR665 (2x AMD EPYC730216C@3.0GHz,128GB RAM, nVidia P2200)
Hi Slicon,
Yes you are right I also have this bug. Steinar will be informed. He is currently on vacation.
Thanks for reporting.
Hi Silicon,
The bug is confirmed and will be fixed for the next release.
