API
mrazik
API
Post by mrazik »
Hi FFAStrans Team,
I don't know if there is a bug or I'm doing something wrong, but when I'm using API control of FFAStrans, there is issue with obtaing job status in some race condition.
API returns no job exists, when the job is moving from running to history.
Many thanks for info,
mrazik
FFAStrans 1.2.2
Webinterface 1.2.0.4
8.00 GB RAM
NVIDIA Quadro K620
256GB SSD
1GB NIC
Windows 10 Pro 64b
Re: API
you mean this?
When the job has finished you call:
http://localhost:65445/api/v2/jobs/20211109-1308-5565-56fe-f2dd182dd3c2
and the response is:
Invalid resource : "/api/v2/jobs/20211109-1308-5565-56fe-f2dd182dd3c2"
Is this what you do?
mrazik
Re: API
Post by mrazik »
yes exactly.
FFAStrans 1.2.2
8.00 GB RAM
NVIDIA Quadro K620
256GB SSD
1GB NIC
Windows 10 Pro 64b
Re: API
Yeah thats by design.
You can try out the new api which is currently shipped with webinterface only but there are plans about merging old api into new one and make new default.
Overview:
http://localhost:3003/
Get Job Details:
http://localhost:3003/getjobdetails?job ... cea7470e81
mrazik
Re: API
Post by mrazik »
I'll try that, thank you for the hint.
Cheers,
mrazik
FFAStrans 1.2.2
8.00 GB RAM
NVIDIA Quadro K620
256GB SSD
1GB NIC
Windows 10 Pro 64b
