Proxyfiles from .m2ts originals get a weird start TC
Christian BH
Post by Christian BH »
Hi Forum.
I've been a Ffastrans user for quite some time, and absolutely love the software. The company I work for has been using Ffastrans for several years, without issues - mainly for creating proxy files for editing.
Recently we noticed that proxyfiles created from .m2ts originals get the following start TC: 00:00:01:01. This should be TC: 00:00:00:00.
This only happens with m2ts-files - nothing else...
Has anyone else experienced this issue? If so - did you find a solution?
Edit - the issue exists in versions 1.2.0.0 and 1.2.2.0, I have not tested with other versions than those atm.
Best regards
Christian
Re: Proxyfiles from .m2ts originals get a weird start TC
Hi Christian,
welcome to the forum and well... thanks to your company for using FFAStrans :D
It would be good if you export and upload your workflow so we can easily reproduce the problem. If this is really source file related, it would be good to have a small source file example as well.
Christian BH
Hi emcodem.
Thanks for the quick reply.
Due to GDPR and copyright issues I cannot share any source files I'm afraid. This is for broadcasting and hasn't been broadcasted yet.
I have attached our workflow to this post - some elements have been translated to Danish. If you need clarification just ask ;)
Christian
Hi Christian,
I think you forgot to join your workflow :) Give it to us, we're gonna see that.
For the records, if you need m2ts files to always start at 00:00:00.00 you can set the timecode manually with the populate variable so that you can save it in a variable and then you can set that variable in the encoding node in the timecode field. ;)
If you want other timecodes to be preserved and only change the ones from m2ts you can add a conditional too that triggers the populate variable only when the condition is true. :)
Christian BH
I attached a file, but it somehow didn't get attached anyway. Trying again now.
The workflow is setup to use the TC of the original, but this in general is changed by 1 sec. and 1 frame with m2ts-files as written earlier.
Ingest.json
(18.97 KiB) Downloaded 720 times
Sorry, the "board attachment quota" was reached, i just raised it.
Please try again and after uploading, hit the "Place inline" button near to the attachment to post a link to the file
Christian BH
emcodem wrote: Tue Jan 11, 2022 8:40 am Sorry, the "board attachment quota" was reached, i just raised it.
Worked now - thanks :)
Hm works as expected for me, but in all testfiles that i have, there is actually some startc detected by mediainfo, maybe this is your problem actually.
Can you check if it is the same for you, like is the "Delay" value set in mediainfo in your input files?
Where would you acutally expect the "TC" to be taken from in your .ts files? Maybe it could help if you just add a workflow path for .ts files and reset the TC in this case?
Christian BH
I will check the files a.s.a.p emcodem and provide feedback.
Thanks for the help so far :)
