Video (MP4) to GIF
authorleon
Video (MP4) to GIF
Post by authorleon »
Unless I've missed something, Is it possible to export to Animated GIF.
Also, having the about to have the keyframe would be great as well.
For example. I could set it to 12FPS or even 3 FPS.
Thank you
Re: Video (MP4) to GIF
Aye authorleon, good to hear from you!
Sure, no problem at all. Check out this example workflow that i created for you:
emcodem_create_gif.json
(4.19 KiB) Downloaded 615 times
authorleon
thank you very much. I'm going to test it out. No doubt your skills are impeccable as always.
It's great to be back. It has been a long time and I missed doing automation. I hope to contribute to the community bit more.
I hope you are doing well!!
emcodem wrote: Wed Nov 23, 2022 2:36 pm Aye authorleon, good to hear from you!
authorleon
I can confirm this works perfectly. I do have a follow-up question. Is there a way to change quality/compression. The reason I ask is that when the GIF is exported. It is quite weighty.
Quite fine i do, thanks! Hope you too :D
Honestly, not sure if gif can be compressed in that sense. Short research tells me that lots of people wondered about it.
I found this post the best: https://superuser.com/questions/1049606 ... ing-ffmpeg
  • here scale and max_colors drastically impacts the output gif's filesize.
Also, he used max_colors 32 and paletteuse=dither=bayer
you could try to alter the ffmpeg command in my example and change the existing word "paletteuse" to "paletteuse=dither=bayer" but that will only do good in combination with the low colors setting, if you need higher, you probably go better with other ditherers: https://ffmpeg.org/ffmpeg-filters.html#paletteuse
