color change "on success" "on both"
RamiHanna
Post by RamiHanna »
I need to change the green and yellow on input at all boxes
the green and yellow is hard to distinguish
cloud we use orange for "on both" and keep the green for "on success"
Re: color change "on success" "on both"
Hey RamiHanna,
welcome to the Forum and thanks for using FFAStrans!
It's not like the colors are accident or quickly selected so we need some better argumenting from you here. Honestly on my monitors the green and yellow is easy to see. On the other hand, orange might be hard to distinguish from red.
You got some color codes for us to make clear what you imagine?
Besides that, are you aware that:
1) color changes would need a new update, it is not something that you can configure anyhow
2) the workflow builder interface is mostly for administrators so not lots of users see it. You can potentially influence the color display on your monitor and/or graphics driver
RamiHanna
Post by RamiHanna »
Hey Emcodem,
I have found the image below showing most distinguish colors to my eye.
what do you think?
I Hope it would be consider on the next update, it will be helpful
thank you
OK great thanks RamiHanna,
well if it was for me, i'd probably make the colors configureable just for you but this is the baby of @admin so let's see what he thinks.
Turning the yellow ("on both") to some orange flavor is not such a bad idea. The complementary color to green ("on success") is red ("on error") and orange sits right in the middle. Will take a look at it but I will probably not make it configurable.
RamiHanna
Post by RamiHanna »
thank you for the considuration
