Fade in/out Audio always enabled
movalex
Post by movalex »
Hi!
I created a workflow with a video fade/out, but despite the Fade Audio is unchecked, it still fades in.
My current version is 1.3.0.2
Re: Fade in/out Audio always enabled
Hm, it's me brain farting long time ago! :oops: :roll:
This filter has not got any attention at all and it simply looks like enabling/disabling audio/video ended unfinished. So I will finish it properly for the next release.
Thanks for reporting!
movalex
Post by movalex »
Also please check on your side for this issue:
The output video has wrong length with the fade effect applied.
With my tests, the file, that was processed with fade and then converted to the DVCPRO, produces output file 2 frames longer. Same workflow with the fade bypassed produces correct length.
DV -12Db.json
(11.03 KiB) Downloaded 655 times
Hi movalex, sorry for this late replay!
I have now addressed this issue in the upcoming 1.3.1 update.
Thanks again for reporting :-)
movalex
Post by movalex »
Thank you for fixing it and for the option for adding black frames!
