Audio conversion to Avid Op-Atom spec
andrezagato
Post by andrezagato »
Me again, fighting with Avid standarts...
I would like to convert WAV files to avid mxf op-atom MXF audio files. I've tried a few custom ffmpeg encoders, but without succcess. Right now I have been importing direclty from avid, when you import, Avid asks the framerate you want and "does it's thing"... the final file is an MXF file.
Here is how it looks on media info json.
"creatingLibrary": {
"name": "MediaInfoLib",
"version": "22.12",
"url": "https://mediaarea.net/MediaInfo"
"media": {
"@ref": "Z:\\Avid MediaFiles\\MXF\\D04_0403_AUDIO_MESA_A\\D04_0403_AA03.E02AF854D085A.mxf",
"track": [
"@type": "General",
"AudioCount": "1",
"OtherCount": "1",
"FileExtension": "mxf",
"Format": "MXF",
"Format_Version": "1.2",
"Format_Profile": "OP-Atom",
"Format_Settings": "Closed / Complete",
"FileSize": "326854882",
"Duration": "2267.999",
"OverallBitRate": "1152928",
"StreamSize": "263014",
"FooterSize": "194",
"PackageName": "A_RS03_040323/003 / D04_0403_A_RS03_040323_003_Tr1.WAV / D04_0403_A_RS03_040323_003_Tr1.WAV:2023-03-04",
"Encoded_Date": "2023-03-06 01:55:17.000",
"File_Created_Date": "UTC 2023-03-06 22:59:55.800",
"File_Created_Date_Local": "2023-03-06 19:59:55.800",
"File_Modified_Date": "UTC 2023-03-06 22:59:58.652",
"File_Modified_Date_Local": "2023-03-06 19:59:58.652",
"Encoded_Application_Version": "Unknown version",
"Encoded_Library_Name": "AAFSDK (MacOS X)",
"Encoded_Library_Version": "2.0.8.102.1",
"extra": {
"IsTruncated": "Yes"
"@type": "Audio",
"ID": "1",
"Format": "PCM",
"Format_Settings_Endianness": "Little",
"Format_Settings_Wrapping": "Clip",
"CodecID": "4B464141000D4D4F",
"BitRate_Mode": "CBR",
"BitRate": "1152000",
"Channels": "1",
"SamplingRate": "48000",
"SamplingCount": "108863952",
"FrameCount": "108863955",
"BitDepth": "24",
"Delay": "0.000",
"Delay_DropFrame": "Yes",
"Delay_Source": "Container",
"StreamSize": "326591868",
"StreamSize_Proportion": "0.99920",
"extra": {
"Locked": "No",
"BlockAlignment": "3"
"@type": "Other",
"ID": "19-Source",
"Type": "Time code",
"Format": "MXF TC",
"FrameRate": "29.970",
"FrameCount": "12947040",
"TimeCode_FirstFrame": "00:00:00;00",
"TimeCode_LastFrame": "119:59:59;29",
"TimeCode_Settings": "Source Package",
"TimeCode_Stripped": "Yes"
Would it be possible to convert it with FFastrans ?
Re: Audio conversion to Avid Op-Atom spec
You can try raw2bmx:
C:\FFAStrans1.3.0.2\Processors\mxf_tools\raw2bmx.exe -t avid -o c:\temp\avid --wave C:\temp\MYSOURCEILFE.wav
