Webinterface 1.3.9.0 and non-Latin1 folder names
Vladimir
Post by Vladimir »
Hello emcodem,
I just upgraded Webinterface 1.2 to latest 1.3.9.0. Thanks for this your great work!
Unfortunately there is a small bug in functionality of Browse frame of SUBMIT JOBS page.
i can't enter folders with names containing characters outside of the Latin1 range.
Folders like:
Nová složka
Նոր թղթապանակ
새 폴더
can't be opened. And
New folder
Nouveau dossier
Ny mappe
Új mappa
are opened.
Web browser (i use Opera) console reports:
Uncaught DOMException: Failed to execute 'btoa' on 'Window': The string to be encoded contains characters outside of the Latin1 range.
Webinterface 1.2 allowed it surely.
Re: Webinterface 1.3.9.0 and non-Latin1 folder names
Hey Vladimir,
sorry i have overseen your post and thanks for the report. Damned, i solved one issue but opened another one :D
It is easy to solve but the affected file is inside server.exe so i fear you'll need to wait a few weeks until next release comes out ^^
Let me know if you need a more urgent solution.
Vladimir wrote: Thu Mar 23, 2023 11:57 am (i use Opera)
is there a technical reason for that? - just curious because Opera is pretty rare...
Vladimir
Post by Vladimir »
Thanks, emcodem.
I'll wait.
Why Opera? Simple habit since 1995.
Vladimir
Post by Vladimir »
Hello emcodem,
i suppose, there no way to workaround the trouble. Or i wrong?
Hehe we changed so much that i fear there are lots of small shortcomings. This is why i hassle with release.
Anyway i wanted to release this since a very long time.
Be aware that you will loose the history jobs but the rest of the config should work. If you have a config. Keep a backup of the old version.
https://github.com/emcodem/ffastrans_we ... 1.3.37.zip
@Vladimir does the new stuff work for you?
Webint 1.4 is now official, it is not much different from the 1.3.37 that i sent. Let me know if it works for you.
