Loudness analyzer started working incorrectly
kovbal
Post by kovbal »
Dear Forum members,
We are experiencing a strange issue with the loudness plugin. Running the latest 1.3.0.2 version, after a while (started two weeks ago) the measurement is incorrect, when we are comparing with other loudness analyzers, and until this time it measured the same as other softwares. Do you have any ideas what could went wrong? No program components have been touched.
Thanks,
Balazs
Re: Loudness analyzer started working incorrectly
Hey Balazs,
From feeling nothing else than workflow settings will change the loudness result. Usually incorrect measurement goes back to wrong audio mapping (e.g. measure as mono instead as stereo).
How much difference is in the result? Can you post
-) a short example file (e.g. sine wave),
-) your workflow
-) the expected result (+ which of the parameters you look at, program or short-term...)
-) the "wrong" result you are getting
