FTP watch folder continuously localize
JFVedia2023
Post by JFVedia2023 »
I set a new computer with Windows 11 pro.
I'm doing some tests with the 1.4.0.1 and 1.4 version.
With an FTP folder monitor, I'm looking for the *.mxf file.
This is a test FTP, I put an mxf file.
The monitor successfully download the file. But some hours later, the file is again downloaded. And some hours later, again.
I don't know why. Nobody changed the file, it's always the same, same filename, same attributes.
We're using the ftp monitor with an older version 1.2.1.0 without this issue.
Does anybody witness this issue ?
Re: FTP watch folder continuously localize
Do you, by any chance, have "Forget missing files" toggled in the FTP monitor?
JFVedia2023
I think you found the clue.
It was enabled by default to the node.
I unchecked it ! Will let it 24 hours, and will see
Thank you :-)
