$timecalc
jeroen.hennekes
$timecalc
Post by jeroen.hennekes »
Can I still use the $timecalc function?
Re: $timecalc
yes, why you ask?
jeroen.hennekes
Re: $timecalc
Just because I found it in the documentation while it doesn't get offered from the interface.
Re: $timecalc
Hm, i see it when opening the Functions selction from a populate processor in latest release... might you explain where you not see it?
jeroen.hennekes
Re: $timecalc
Exactly where you see it...
I guess I wrongly assumed $timecalc is an old function: I am at 1.3.1.14 and should update to 1.4.0.1
Sorry to bother you.
Re: $timecalc
Yeah i fear its a new function :D Enjoy the new version then!
jeroen.hennekes
Re: $timecalc
Successfully used it in the populate variables node for the weekly creation of a Gdrive date folder for auto resizing the images supplied by the editors to serve in coming wednesday and thursday EmmaTV weekly broadcasts. Just one remark:
The usage declaration in the web documentation and the interface ? help file is obviously a copy/paste from the $dateweek one above it.
https://ffastrans.com/wiki/doku.php?id= ... s#dateweek
Re: $timecalc
Yeah, thanks for spotting the shortcoming, @admin will fix the documentation.
How do you connect to gdrive? i guess just sync the files to local using some sync tool?
jeroen.hennekes
Re: $timecalc
Our QNAP NAS offers the Cloud Drive Sync app for syncing with several storage services, like Gdrive.
Thanks to you guys for this awesome workflow app :!: and the way you offer support :!: :!:
