Hi All
I searched but I cannot found if there is a way to chose the color of each line in the statut monitor (red or green) ?
I have a workflow with too branches : before encoding, I test if the user inputs a correct file in the watchfolder. If not, the workflow end without encoding and I'am using the "Success" variable to add a message in the statut monitor to indicate what's wrong. Now I would like to put this line in red and not in green.
Thank you guy
Color statut monitor line
Re: Color statut monitor line
Hey Ghtais,
if you mean the inbuilt status monitor application, there is no way to influence row colors. In webint you have it under the "options" btn
ok thank you,
P.S : it could be a great new feature for next update
