Lowercase for wrapper in audio extraction
DCCentR
Post by DCCentR »
Happy New Year and Merry Christmas, guys!
Would like to see wrapper name (file extension) in lower case by default in audio extraction processor, or to be able to choose between upper case or lower case. This may be necessary because some software can be sensitive to case-sensitive file extensions. Yes we can manually edit the json, but it is not very convenient and can be forgotten & etc.
Снимок экрана 2025-01-23 121001.png (39.27 KiB) Viewed 26360 times
Снимок экрана 2025-01-23 121225.png (25.13 KiB) Viewed 26360 times
Re: Lowercase for wrapper in audio extraction
:sweat_smile:
Well, on the Delivery node you can always tick the box that removes the extension and add "wav" as lowercase (at least that's how I've done it), which is probably easier to remember than editing the json, especially given that any other change to the workflow would override the json if you're trying to edit it.
By the way, the DP600, a 17 (soon to turn 18) years old machine from Dolby also doesn't like .WAV as capital, so that's why I'm renaming it with the delivery node. ;)
