Grafana "No dashboards found"
JoshKn
Post by JoshKn »
Hey,
last week I've set up a processing farm and everything runs perfectly. The only problem I ran into is that, in the Metrics tab, Grafana can't find any dashboards.
Metrics server and client are installed on the server, while every processing machine has the Metrics client installed as well. They all show up under "Metrics/setup" with port 9182 displayed as "Up".
I can also access Grafana at [Server-IP]:3004 but every time I do, no dashboards are displayed. In the webinterface under "Metrics" I get the error message "No dashboards found".
At "C:\ffastrans\webinterface_1.4.0.107\tools\prometheus\grafana_dashboards\" are by default two JSON files "Windows Node with process info-1645374819792.json" and "FFAStrans Running-1645374845637.json". As those did not work, I tried copying them to different locations like "\prometheus\grafana-7.4.3\dashboards" but that also did not work.
Did I make a mistake or did something go wrong? I'm out of ideas :D
Thanks for any help!
Re: Grafana "No dashboards found"
Hi JoshKn,
yeah sorry for that, the metrics are the next thing i am going to overhaul or better i just started to tear down the grafana integration in webinterface in a way that in future it is not "integrated" in webint as it is now.
You can just download normal grafana, add "prometheus" datasource and import the dashboards for now.
