Right click entry to quick browse to location
lue3099
Post by lue3099 »
Hello!
It would be nice if on the monitor and delivery nodes, we can right-click, and there be an option to open explorer to that location that is entered into the "Folder: " section of the node.
Like this:
Kind Regards,
Lue.
Re: Right click entry to quick browse to location
Hi lue3099, sorry for the late reply!
At first it might look like a good idea but this menu is generic to all nodes. Picking one particular setting from one or more particular node(s) and exposing it like that is very ad-hoc and bad design. Another problem, especially with the delivery node; depending on the configuration, the destination might be totally unknown until a job actually exists. So it would be impossible to go to an unknown location.
So it's not the correct context for such a feature.
I add to Steinar's answer that you can easily edit your monitor node and click here :
If your source path is reachable, you will entered in it.
cheers ;)
