Youtube-DL/YT-DLP | Extracting media information
Post by taner »
Hi Admin Team,
Hope you are fine.
I have a problem.
When using Youtube decoder the step "Extracting media information" takes forever.
File will not be downloaded.
It worked until it didnt.
That makes me very sad.
As far as I can see YT-DLP within ffastrans folder is the latest release.
When I submit the same url via command line and without any additional arguments the file will be downloaded.
Following is repeatedly logged in FFAStrans, over and over:
WARNING: ffmpeg not found. The downloaded format may not be the best available. Installing ffmpeg is strongly recommended:
WARNING: [youtube] yUi_S6YWjZw: Some web client https formats have been skipped as they are missing a url. YouTube is forcing SABR streaming for this client.
WARNING: [youtube] yUi_S6YWjZw: Some tv client https formats have been skipped as they are DRM protected. The current session may have an experiment that applies DRM to all videos on the tv client.
Im aware that it is a third party app but maybe it could be interesting for you that there may be currently a potential issue/limitation in some config.
Best
Taner
Re: Youtube-DL/YT-DLP | Extracting media information
Hey @taner
woow interesting. Do you know if it works when testing locally because in this case ytdlp finds ffmpeg? E.g. can you place ffmpeg.exe in c:\windows\system32 and check again if it works then in ffastrans?
Can you give me a yt url to reproduce this?
Post by taner »
Hi emcodem!
Thanks for reply.
I've tested a little bit more.
And as far as I can see it is related to those urls where a playlist exists.
But: in my case in FFAStrans playlist is not allowed and regardless of that it won't download those which are part of a playlist.
If there is no playlist then download in FFAStrans works.
And from command line, locally, it always works.
Regardless I set --yes-playlist or not.
Paradoxically it won't download the whole playlist even if I set --yes-playlist.
But maybe I'm missing another argument.
Anyway.
Here are 2 examples.
playlist
https://www.youtube.com/watch?v=_KhuVZE ... xyEVy6Ey9_
no playlist
https://www.youtube.com/watch?v=sr0my4PAn80
Stef
Post by Stef »
Hey taner
I had the same issue recently, but managed to get a workaround:
Enable the Bypass checkbox in the YouTube decoder, this will output the URL in the %s_source% variable. Next create a Populate Variables node and set %s_source% to the following:
$regext("%s_source%",".+?(?=&)")
This will remove everything after the first & symbol, cleaning the URL of any extra parameters. Send that to a regular YouTube decoder, and it should work again.
EDIT: A conditional to check if there's an & character in the URL is required, that regex will return nothing if it can't find an &, so the following YouTube decoder will fail silently.
