Wishlist
mihai
Wishlist
Post by mihai »
Hi.
Do you think will be possible to add two more options/features to ffastrans?
- remember main & monitor windows size and position
- adding another variable %parent_folder% (ex. parent_folder="dvcam" from full path "c:\ffastrans\video\dvcam")
best regards,
mihai
P.S. - Thank for FFAStrans!
Re: Wishlist
Hi mihai,
Your first request is a no-brainer. It ought to be added long ago. :oops: Consider it done!
Also, I would like to expand a bit on your second request. Having a separate variable for parent folder seems a bit ad hoc. Instead, I would like to make all parent folders available to the user, like this:
%original_path%=c:\ffastrans\video\dvcam
%original_path~1%=dvcam
%original_path~2%=video
%original_path~3%=ffastrans
...and so forth. I think that would be a powerful type of variable.
Thanks for you excellent wishlist! :-)
