Single Still To Video
graham728
Post by graham728 »
It may be obvious but I've tried without success.
I want to take a single PNG and make it into a five second video. Not sure how to do this?
Re: Single Still To Video
Hey Graham,
if you can use A/V decoder, just do it with a Custom Avisynth script:
m_clip=loop(m_clip,250,0)
Return m_clip
Above means repeat frame 0 250 times, i think it would also work when written as m_clip=loop(m_clip,250)
Let me know if it works for you!
EDIT: we also have it in the stills decoder, i forgot... i believe it will do more or less the same internally but not 100% sure about it
emcodem wrote: Thu Nov 27, 2025 11:31 am i believe it will do more or less the same internally
Yep. I mean, kinda, but yeah. :) Well this
Screenshot 2025-11-30 221418.png (7.3 KiB) Viewed 9549 times
just like the A/V Decoder is going through an indexer, in this case ImageSource().
If we were writing a script from scratch, we would use the indexer to index the image and specify how many frames and at what framerate we want the image to become in the uncompressed A/V stream in our beloved frameserver.
For instance, to get 2 seconds (i.e 50 frames at 25fps) we would specify:
Screenshot 2025-11-30 222213.png (286.49 KiB) Viewed 9549 times
and that's exactly what we're doing in FFAStrans as well, namely using the indexer. :D
ImageSource("' & $s_JOB_ORIGINAL_LOCAL_FILE & '", start = 0, end = ' & $i_PROC_LENGTH & ', fps = ' & $i_PROC_FPS & ')'
where the end is always calculated (i.e converted in frames) from the variable read from the user input and so are the fps. :)
