Source Move Issue
vijm1972
Source Move Issue
Post by vijm1972 »
Dear Steipal,
I am trying to move source file's to "Backup Folder" path but files are moving to "Work Folder'. I am using FFAStrans version "FFAStrans0.5.0_Win32", this version solved my old request creating ".backup folders" but still completed source files are not moving to provided path. I had configured workflow on which I have created my work folder on "C:\Test\Work Folder" and my source files need to move on "C:\Test\Completed Source". I had use Backup Folder path for moving source files.
Can you please suggest.
Vijay
Re: Source Move Issue
I can't believe that one passed my tests :oops: Sorry about that!
It will off course be fixed for the next release.
vijm1972
Post by vijm1972 »
After Updating FFAStrans, issue resolved...... Thank You!!!
