Move source files after succesful encoding
stussi
Post by stussi »
Is it possible to move the source files in another directory after a succesful encoding?
Re: Move source files after succesful encoding
Currently it's not possible to move files based upon whether they've been successfully transcoded. However, there has been some calls for this kind of feature so within a few versions it should be present.
You can move ALL files processed but that is probably not what you want?
stussi
Post by stussi »
Move all the files processed can be also a solution. It seems to work if I enable both backup and delete original feature, right? Is there another way?
No, that is the way to move all files but there is a bug in the latest version that prevents it from doing it correctly. It will fixed in the next version.
stussi
Post by stussi »
Mmmh I made some test and it works for me. What kind of bug are you talking about?
In the current version, FFAStrans will disregard user specified backup folder and use the default.
