Hello Steipal,
I am transcodeing 19 Mins .mxf source file using FFAStrans, source file is corrupt after 11 Mins. FFAStrans transcode the file till 11 Mins and stopped transcoding, showing message in Outcome success. Is it possible to check and verify the source before transcode in FFAStrans? Is their any command in FFMPEG to check and verify the output file duration with source file duration?
Vijay
How to verify source video content in FFAStrans?
Re: How to verify source video content in FFAStrans?
You can check media duration by running the following command:
ffmpeg.exe -i <yourfile> <outfile.avi>
ffmpeg.exe can be found in the "Processors\FFmpeg"-folder in your FFAStrans folder.
If the you get any errors and it stops after 11 minutes then you're probably out of luck using DFAStrans. It can do only so much with corrupt files. Now, if you want to check an entire file for errors FFAStrans must read through the whole file in order to detect any anomalies. At the moment there is no such options built into FFAStrans but I think it might be a good thing to offer
I am using automated folder watch option to process below file. My problem is source file has an issue after 11 Mins, but FFAStrans not showing any error while processing or after processing. File processed successfully. FFAStrans actually need to show some error. I have got 11 Mins files in output which we had sent to client without checking the duration, because there is no error in monitor window.
Now I wanted to add some FFMPEG command which will automatically stop processing any corrupt files or check and confirm source and target file duration while processing. Is it possible?
I understand your problem but I need to know whether ffmpeg sees all the 19 minutes or if it reports only 11. That's why I need you help me and do the commands from my previous post. However, if you're not comfortable with running dos-commands you need to turn on logging and send me the log-file. You can turn on logging under the "Special" tab in "Workflow setup" and select "Log to files" and save the workflow. Now manually submit the corrupted file and upon completion open the folder displayed in the "Special" tab. Send me the log file that was generated for the job and I'll have a look at it.
Currently, there is no easy way of doing what you want but let me think about it for a while
Below are the logs for your reference.
==> 2015-07-29 13:21:51.345 on Folder@TN-TRANS-22, PID: 3816 -> Ticketfile is "Z:\Processors\.cache\tickets\x20150729-132150-160-8BD57CC7_20150728162400~glob~TN-TRANS-22~20150729-132149-832-F0816278.ini"
==> 2015-07-29 13:21:51.361 on Folder@TN-TRANS-22, PID: 3816 -> Source is Y:\FFMPEG\MXF_MXF\Inbox\62ND FILMFARE AWARDS SOUTH 2014 - SEG1_1_V177506A.mxf
==> 2015-07-29 13:21:51.361 on Folder@TN-TRANS-22, PID: 3816 -> Getting top storage...
==> 2015-07-29 13:21:51.392 on Folder@TN-TRANS-22, PID: 3816 -> Setting work folder to "\\tnc1\Techtest\FFMPEG\Workfolder\20150728162400\20150729-132149-832-F0816278"
==> 2015-07-29 13:21:51.392 on Folder@TN-TRANS-22, PID: 3816 -> Creating work dir: \\tnc1\Techtest\FFMPEG\Workfolder\20150728162400\20150729-132149-832-F0816278
==> 2015-07-29 13:21:51.470 on Folder@TN-TRANS-22, PID: 3816 -> Registering abort check...
==> 2015-07-29 13:21:51.486 on Folder@TN-TRANS-22, PID: 3816 -> Executing ini: "mon_folder 20150728162406"
==> 2015-07-29 13:21:51.486 on Folder@TN-TRANS-22, PID: 3816 -> Executing sys: "mon_folder 20150728162406"
==> 2015-07-29 13:21:51.501 on Folder@TN-TRANS-22, PID: 3816 -> ProcessorEnd_Routine(mon_folder 20150728162406)
==> 2015-07-29 13:21:51.517 on Folder@TN-TRANS-22, PID: 3816 -> Ending process...
==> 2015-07-29 13:21:53.342 on Custom FFmpeg@TN-TRANS-22, PID: 2300 -> Ticketfile is "Z:\Processors\.cache\tickets\x20150729-132152-219-7873BC86_20150728162400~glob~TN-TRANS-22~20150729-132149-832-F0816278.ini"
==> 2015-07-29 13:21:53.342 on Custom FFmpeg@TN-TRANS-22, PID: 2300 -> Source is Y:\FFMPEG\MXF_MXF\Inbox\62ND FILMFARE AWARDS SOUTH 2014 - SEG1_1_V177506A.mxf
==> 2015-07-29 13:21:53.358 on Custom FFmpeg@TN-TRANS-22, PID: 2300 -> Creating work dir: \\tnc1\Techtest\FFMPEG\Workfolder\20150728162400\20150729-132149-832-F0816278
==> 2015-07-29 13:21:53.358 on Custom FFmpeg@TN-TRANS-22, PID: 2300 -> Registering abort check...
==> 2015-07-29 13:21:53.373 on Custom FFmpeg@TN-TRANS-22, PID: 2300 -> Executing ini: "enc_av_customff 20150728162447"
==> 2015-07-29 13:21:53.373 on Custom FFmpeg@TN-TRANS-22, PID: 2300 -> Executing sys: "enc_av_customff 20150728162447"
==> 2015-07-29 13:21:53.405 on Custom FFmpeg@TN-TRANS-22, PID: 2300 -> _IPS_SRV_ClipCheck(Y:\FFMPEG\MXF_MXF\Inbox\62ND FILMFARE AWARDS SOUTH 2014 - SEG1_1_V177506A.mxf,enc_av_customff,0)
==> 2015-07-29 13:21:53.405 on Custom FFmpeg@TN-TRANS-22, PID: 2300 -> _WaitForResources()
==> 2015-07-29 13:21:53.405 on Custom FFmpeg@TN-TRANS-22, PID: 2300 -> _WaitForResources() ==> Resources obtained.
==> 2015-07-29 13:21:54.512 on Custom FFmpeg@TN-TRANS-22, PID: 2300 -> _Check_FF_Output(\\tnc1\Techtest\FFMPEG\Workfolder\20150728162400\20150729-132149-832-F0816278\~enc_av_customff_20150728162447_132153405.txt,0)
==> 2015-07-29 13:21:54.528 on Custom FFmpeg@TN-TRANS-22, PID: 2300 -> _IPS_ClipInfo(C:\Windows\system32\cmd.exe /c ""Z:\Processors\FFMpeg\ffmpeg.exe" -i "Y:\FFMPEG\MXF_MXF\Inbox\62ND FILMFARE AWARDS SOUTH 2014 - SEG1_1_V177506A.mxf" 2>> "\\tnc1\Techtest\FFMPEG\Workfolder\20150728162400\20150729-132149-832-F0816278\~enc_av_customff_20150728162447_132153405.txt""
ffmpeg version N-72298-g02cf59f Copyright (c) 2000-2015 the FFmpeg developers
built with gcc 4.9.2 (GCC)
configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libdcadec --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-lzma --enable-decklink --enable-zlib
libavutil 54. 23.101 / 54. 23.101
libavcodec 56. 40.100 / 56. 40.100
libavformat 56. 33.101 / 56. 33.101
libavdevice 56. 4.100 / 56. 4.100
libavfilter 5. 16.101 / 5. 16.101
libswscale 3. 1.101 / 3. 1.101
libswresample 1. 1.100 / 1. 1.100
libpostproc 53. 3.100 / 53. 3.100
[mxf @ 02b4d7c0] invalid KAGSize 0 - guessing 1
Guessed Channel Layout for Input Stream #0.1 : mono
Guessed Channel Layout for Input Stream #0.2 : mono
Guessed Channel Layout for Input Stream #0.3 : mono
Guessed Channel Layout for Input Stream #0.4 : mono
Input #0, mxf, from 'Y:\FFMPEG\MXF_MXF\Inbox\62ND FILMFARE AWARDS SOUTH 2014 - SEG1_1_V177506A.mxf':
Metadata:
uid : 91ffff91-2833-e511-98be-dfecce27447b
generation_uid : 92ffff91-2833-e511-a784-dfecce27447b
company_name : Omneon Inc.
product_name : Omneon Media Subsystem
modification_date: 2015-07-25 23:55:04
product_version : 7.2.0.0.release
application_platform: Omneon Media Api (windows)
product_uid : 00000000-0000-0010-8000-050e0b010603
material_package_umid: 0x060A2B340101010501010D231300BB419CFFFF912833E511A6E9DFECCE27447B
timecode : 09:59:50:00
Duration: 00:19:56.56, start: 0.000000, bitrate: 10216 kb/s
Stream #0:0: Video: mpeg2video (4:2:2), yuv422p(tv), 720x576 [SAR 16:15 DAR 4:3], 15000 kb/s, 25 fps, 25 tbr, 25 tbn, 50 tbc
Metadata:
file_package_umid: 0x060A2B340101010501010D231300B30B9EFFFF912833E511AEA6DFECCE27447B
Stream #0:1: Audio: pcm_s16le, 48000 Hz, 1 channels, s16, 768 kb/s
Metadata:
Stream #0:2: Audio: pcm_s16le, 48000 Hz, 1 channels, s16, 768 kb/s
Metadata:
Stream #0:3: Audio: pcm_s16le, 48000 Hz, 1 channels, s16, 768 kb/s
Metadata:
Stream #0:4: Audio: pcm_s16le, 48000 Hz, 1 channels, s16, 768 kb/s
Metadata:
At least one output file must be specified
,Frames,0)
==> 2015-07-29 13:21:54.606 on Custom FFmpeg@TN-TRANS-22, PID: 2300 -> _IPS_ClipInfo(C:\Windows\system32\cmd.exe /c ""Z:\Processors\FFMpeg\ffmpeg.exe" -i "Y:\FFMPEG\MXF_MXF\Inbox\62ND FILMFARE AWARDS SOUTH 2014 - SEG1_1_V177506A.mxf" 2>> "\\tnc1\Techtest\FFMPEG\Workfolder\20150728162400\20150729-132149-832-F0816278\~enc_av_customff_20150728162447_132153405.txt""
Metadata:
Metadata:
Metadata:
Metadata:
Metadata:
Metadata:
,Audio,0)
==> 2015-07-29 13:21:54.652 on Custom FFmpeg@TN-TRANS-22, PID: 2300 -> _IPS_ClipInfo(C:\Windows\system32\cmd.exe /c ""Z:\Processors\FFMpeg\ffmpeg.exe" -i "Y:\FFMPEG\MXF_MXF\Inbox\62ND FILMFARE AWARDS SOUTH 2014 - SEG1_1_V177506A.mxf" 2>> "\\tnc1\Techtest\FFMPEG\Workfolder\20150728162400\20150729-132149-832-F0816278\~enc_av_customff_20150728162447_132153405.txt""
Metadata:
Metadata:
Metadata:
Metadata:
Metadata:
Metadata:
,Audio,1)
==> 2015-07-29 13:21:54.715 on Custom FFmpeg@TN-TRANS-22, PID: 2300 -> _IPS_ClipInfo(C:\Windows\system32\cmd.exe /c ""Z:\Processors\FFMpeg\ffmpeg.exe" -i "Y:\FFMPEG\MXF_MXF\Inbox\62ND FILMFARE AWARDS SOUTH 2014 - SEG1_1_V177506A.mxf" 2>> "\\tnc1\Techtest\FFMPEG\Workfolder\20150728162400\20150729-132149-832-F0816278\~enc_av_customff_20150728162447_132153405.txt""
Metadata:
Metadata:
Metadata:
Metadata:
Metadata:
Metadata:
,Audio,2)
==> 2015-07-29 13:21:54.808 on Custom FFmpeg@TN-TRANS-22, PID: 2300 -> _IPS_ClipInfo(C:\Windows\system32\cmd.exe /c ""Z:\Processors\FFMpeg\ffmpeg.exe" -i "Y:\FFMPEG\MXF_MXF\Inbox\62ND FILMFARE AWARDS SOUTH 2014 - SEG1_1_V177506A.mxf" 2>> "\\tnc1\Techtest\FFMPEG\Workfolder\20150728162400\20150729-132149-832-F0816278\~enc_av_customff_20150728162447_132153405.txt""
Metadata:
Metadata:
Metadata:
Metadata:
Metadata:
Metadata:
,Audio,3)
==> 2015-07-29 13:21:54.871 on Custom FFmpeg@TN-TRANS-22, PID: 2300 -> _IPS_ClipInfo(C:\Windows\system32\cmd.exe /c ""Z:\Processors\FFMpeg\ffmpeg.exe" -i "Y:\FFMPEG\MXF_MXF\Inbox\62ND FILMFARE AWARDS SOUTH 2014 - SEG1_1_V177506A.mxf" 2>> "\\tnc1\Techtest\FFMPEG\Workfolder\20150728162400\20150729-132149-832-F0816278\~enc_av_customff_20150728162447_132153405.txt""
Metadata:
Metadata:
Metadata:
Metadata:
Metadata:
Metadata:
,Audio,4)
==> 2015-07-29 13:21:54.949 on Custom FFmpeg@TN-TRANS-22, PID: 2300 -> _WaitForResources()
==> 2015-07-29 13:21:54.964 on Custom FFmpeg@TN-TRANS-22, PID: 2300 -> _WaitForResources() ==> Resources obtained.
==> 2015-07-29 13:21:54.964 on Custom FFmpeg@TN-TRANS-22, PID: 2300 -> _Simple_MediaOutput executing: C:\Windows\system32\cmd.exe /c ""Z:\Processors\FFMpeg\ffmpeg.exe" -i "Y:\FFMPEG\MXF_MXF\Inbox\62ND FILMFARE AWARDS SOUTH 2014 - SEG1_1_V177506A.mxf" -c:v mpeg2video -s 720x576 -r 25 -aspect 4:3 -vb 15000000 -mbd 2 -trellis 1 -timecode 10:00:00:00 -top 1 -flags +ildct+ilme -alternate_scan 1 -c:a copy -metadata creation_time="2015-07-29 13:21:54" -y "\\tnc1\Techtest\FFMPEG\Workfolder\20150728162400\20150729-132149-832-F0816278\~orlkyqg.mxf" 2>> "\\tnc1\Techtest\FFMPEG\Workfolder\20150728162400\20150729-132149-832-F0816278\~orlkyqg.mxf_ff_pipe.txt""
==> 2015-07-29 13:21:55.011 on Custom FFmpeg@TN-TRANS-22, PID: 2300 -> _IPS_SRV_FFMon(C:\Windows\system32\cmd.exe /c ""Z:\Processors\FFMpeg\ffmpeg.exe" -i "Y:\FFMPEG\MXF_MXF\Inbox\62ND FILMFARE AWARDS SOUTH 2014 - SEG1_1_V177506A.mxf" 2>> "\\tnc1\Techtest\FFMPEG\Workfolder\20150728162400\20150729-132149-832-F0816278\~enc_av_customff_20150728162447_132153405.txt""
Metadata:
Metadata:
Metadata:
Metadata:
Metadata:
Metadata:
,\\tnc1\Techtest\FFMPEG\Workfolder\20150728162400\20150729-132149-832-F0816278\~orlkyqg.mxf_ff_pipe.txt,3228,_IPS_SRV_FFMon)
==> 2015-07-29 13:21:55.027 on Custom FFmpeg@TN-TRANS-22, PID: 2300 -> _IPS_ClipInfo(C:\Windows\system32\cmd.exe /c ""Z:\Processors\FFMpeg\ffmpeg.exe" -i "Y:\FFMPEG\MXF_MXF\Inbox\62ND FILMFARE AWARDS SOUTH 2014 - SEG1_1_V177506A.mxf" 2>> "\\tnc1\Techtest\FFMPEG\Workfolder\20150728162400\20150729-132149-832-F0816278\~enc_av_customff_20150728162447_132153405.txt""
Metadata:
Metadata:
Metadata:
Metadata:
Metadata:
Metadata:
,Frames,0)
==> 2015-07-29 13:28:57.398 on Custom FFmpeg@TN-TRANS-22, PID: 2300 -> _IPS_SRV_ClipCheck(\\tnc1\Techtest\FFMPEG\Workfolder\20150728162400\20150729-132149-832-F0816278\~orlkyqg.mxf,_Simple_MediaOutput,0)
==> 2015-07-29 13:28:57.413 on Custom FFmpeg@TN-TRANS-22, PID: 2300 -> _WaitForResources()
==> 2015-07-29 13:28:57.413 on Custom FFmpeg@TN-TRANS-22, PID: 2300 -> _WaitForResources() ==> Resources obtained.
==> 2015-07-29 13:29:00.580 on Custom FFmpeg@TN-TRANS-22, PID: 2300 -> _Check_FF_Output(\\tnc1\Techtest\FFMPEG\Workfolder\20150728162400\20150729-132149-832-F0816278\~enc_av_customff_20150728162447_132857413.txt,0)
==> 2015-07-29 13:29:00.596 on Custom FFmpeg@TN-TRANS-22, PID: 2300 -> _IPS_ClipInfo(C:\Windows\system32\cmd.exe /c ""Z:\Processors\FFMpeg\ffmpeg.exe" -i "\\tnc1\Techtest\FFMPEG\Workfolder\20150728162400\20150729-132149-832-F0816278\~orlkyqg.mxf" 2>> "\\tnc1\Techtest\FFMPEG\Workfolder\20150728162400\20150729-132149-832-F0816278\~enc_av_customff_20150728162447_132857413.txt""
Input #0, mxf, from '\\tnc1\Techtest\FFMPEG\Workfolder\20150728162400\20150729-132149-832-F0816278\~orlkyqg.mxf':
Metadata:
uid : adab4424-2f25-4dc7-92ff-29bd000c0000
generation_uid : adab4424-2f25-4dc7-92ff-29bd000c0001
company_name : FFmpeg
product_name : OP1a Muxer
product_version : 56.33.101
product_uid : adab4424-2f25-4dc7-92ff-29bd000c0002
modification_date: 2015-07-29 13:21:54
material_package_umid: 0x060A2B340101010501010D001339A3D552947134AF39A3D50052947134AF3900
timecode : 10:00:00:00
Duration: 00:11:15.28, start: 0.000000, bitrate: 15626 kb/s
Stream #0:0: Video: mpeg2video (4:2:2), yuv422p(tv), 720x576 [SAR 16:15 DAR 4:3], max. 104857 kb/s, 25 fps, 25 tbr, 25 tbn, 50 tbc
Metadata:
file_package_umid: 0x060A2B340101010501010D001339A3D552947134AF39A3D50052947134AF3901
Metadata:
,Frames,0)
==> 2015-07-29 13:29:00.627 on Custom FFmpeg@TN-TRANS-22, PID: 2300 -> ProcessorEnd_Routine(enc_av_customff 20150728162447)
==> 2015-07-29 13:29:00.642 on Custom FFmpeg@TN-TRANS-22, PID: 2300 -> Ending process...
==> 2015-07-29 13:29:01.766 on Folder@TN-TRANS-22, PID: 800 -> Ticketfile is "Z:\Processors\.cache\tickets\x20150729-132900-876-A3FDA44A_20150728162400~glob~TN-TRANS-22~20150729-132149-832-F0816278.ini"
==> 2015-07-29 13:29:01.781 on Folder@TN-TRANS-22, PID: 800 -> Source is \\tnc1\Techtest\FFMPEG\Workfolder\20150728162400\20150729-132149-832-F0816278\~orlkyqg.mxf
==> 2015-07-29 13:29:01.797 on Folder@TN-TRANS-22, PID: 800 -> Creating work dir: \\tnc1\Techtest\FFMPEG\Workfolder\20150728162400\20150729-132149-832-F0816278
==> 2015-07-29 13:29:01.797 on Folder@TN-TRANS-22, PID: 800 -> Registering abort check...
==> 2015-07-29 13:29:01.812 on Folder@TN-TRANS-22, PID: 800 -> Executing ini: "dest_folder 20150728162427"
==> 2015-07-29 13:29:01.828 on Folder@TN-TRANS-22, PID: 800 -> Executing sys: "dest_folder 20150728162427"
==> 2015-07-29 13:29:32.107 on Folder@TN-TRANS-22, PID: 800 -> ProcessorEnd_Routine(dest_folder 20150728162427)
==> 2015-07-29 13:29:32.123 on Folder@TN-TRANS-22, PID: 800 -> Job completed without errors.
==> 2015-07-29 13:29:32.138 on Folder@TN-TRANS-22, PID: 800 -> _EnumIfNewJob() with current queue:0
==> 2015-07-29 13:29:32.154 on Folder@TN-TRANS-22, PID: 800 -> Ending process...
Metadata:
Metadata:
Metadata:
Metadata:
Metadata:
Metadata:
,Frames,0)
Metadata:
Metadata:
Metadata:
Metadata:
Metadata:
Metadata:
,Audio,0)
Metadata:
Metadata:
Metadata:
Metadata:
Metadata:
Metadata:
,Audio,1)
Metadata:
Metadata:
Metadata:
Metadata:
Metadata:
Metadata:
,Audio,2)
Metadata:
Metadata:
Metadata:
Metadata:
Metadata:
Metadata:
,Audio,3)
Metadata:
Metadata:
Metadata:
Metadata:
Metadata:
Metadata:
,Audio,4)
Metadata:
Metadata:
Metadata:
Metadata:
Metadata:
Metadata:
Metadata:
Metadata:
Metadata:
Metadata:
Metadata:
Metadata:
,Frames,0)
Metadata:
Metadata:
Metadata:
,Frames,0)
