Delivery to Folder: Labels for suffix and prefix swapped
bephop
Post by bephop »
in the settings for delivery into a folder, the labels for suffix and prefix are swapped.
Normally the suffix comes after the name and the prefix is before the name.
Thanks,
bephop
Re: Delivery to Folder: Labels for suffix and prefix swapped
Hi bephop and thank you for using FFAStrans and thank you for reporting this stupid mistake :oops:
It will of course be fixed in the next release.
bephop
Post by bephop »
Hi steipal,
thank you. And many thanks for programming this very cool tool! I think it's the best watchfolder tool for ffmpeg! Support for growing files and such a nice status monitor is very rare.
I recently used it for professional TV production, transcoding DNxHD to MP4 and vice versa. And the best: I used a serivce wrapper to install FFAStrans as a background service. But you can still open a second instance of FFAStrans to change the configuration. And those changes take instantly effect on the background service.
Maybe you can think about an "install as a service" button ;)
I just had to use a custom ffmpeg command because your DNxHD preset doesn't fit to our requirements.
Hi bephop,
I'm very glad you like FFAStrans and that you find new ways of utilizing the program! :-) A service-option like you suggest will probably find its way into FFAStrans within a few versions but currently it's is not my top priority.
What are the options you're missing in the DNxHD encoder?
bephop
Post by bephop »
Hi steipal,
mainly its the audio part.
Your setup generates one audio stream with e.g. 8 channels in 16bit PCM. But our video server requieres 8 audio streams with one channel in 24bit PCM. Same if you only use 4 channels. Every channel has to be a single mono stream with 24bit encoding.
If the source file has only 2 channels, the other channels should be muted. So you have to map a mute audio source to those streams.
So if i want to transcode from a MP4 file (e.g. shot with a DSLR/GoPro, o a final movie, made for online content. or maybe a youtube video) the whole ffmpeg string looks like this:
ffmpeg -i input.mp4 -f lavfi -i aevalsrc=0 -vcodec dnxhd -vf scale=1920:1080 -b:v 120M -pix_fmt yuv422p -r 25 -flags +ildct+ilme -top 1 -dc 10 -qmax 20 -lmin "1*QP2LAMBDA" -rc_max_vbv_use 1 -rc_min_vbv_use 1 -maxrate 120M -bufsize 8000k -map_metadata 1 -acodec pcm_s24le -ar 48000 -ac 1 -map 0:v -map 0:1 -map_channel 0.1.0:0.1 -map 0:1 -map_channel 0.1.1:0.2 -map 1:0 -map 1:0 -map 1:0 -map 1:0 -map 1:0 -map 1:0 -shortest -color_range 1 -color_primaries 1 -color_trc 1 -f mov output.mov
This includes color conversion, interlacing and audio mapping. The ouput file is compatible with an EVS video server.
Here is a media info of a sample video in DNxHD with 8 Channels:
General
Complete name                            : C:\Offline\FFmpeg\input\dnxtest.mxf
Format                                   : MXF
Commercial name                          : DNxHD 120
Format version                           : 1.3
Format profile                           : OP-1a
Format settings                          : Closed / Complete
File size                                : 934 MiB
Duration                                 : 1mn 0s
Overall bit rate                         : 131 Mbps
Encoded date                             : 2015-05-27 12:40:37.112
Writing application                      : OpenCube MXFTk Advanced 2.7.0.0.1
Writing library                          : Microsoft Windows 7 Professional Service Pack 1 (Build 7601) 2.7.0.0.1
Video
Format                                   : VC-3
Format version                           : Version 1
Format settings, wrapping mode           : Frame
Codec ID                                 : 0D01030102110100-0401020271080000
Duration                                 : 1mn 0s
Bit rate mode                            : Constant
Bit rate                                 : 121 Mbps
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Display aspect ratio                     : 16:9
Frame rate                               : 25.000 fps
Color space                              : YUV
Chroma subsampling                       : 4:2:2
Bit depth                                : 8 bits
Scan type                                : Interlaced
Scan order                               : Top Field First
Bits/(Pixel*Frame)                       : 2.339
Stream size                              : 867 MiB (93%)
Title                                    : Picture
Audio #1
Format                                   : PCM
Format settings, Endianness              : Little
Format settings, wrapping mode           : Frame (AES)
Codec ID                                 : 0D01030102060300-040202017F000000
Duration                                 : 1mn 0s
Bit rate                                 : 1 152 Kbps
Channel(s)                               : 1 channel
Sampling rate                            : 48.0 KHz
Bit depth                                : 24 bits
Stream size                              : 8.24 MiB (1%)
Title                                    : Sound
Audio #2
Format                                   : PCM
Duration                                 : 1mn 0s
Bit depth                                : 24 bits
Title                                    : Sound
Audio #3
Format                                   : PCM
Duration                                 : 1mn 0s
Bit depth                                : 24 bits
Title                                    : Sound
Audio #4
Format                                   : PCM
Duration                                 : 1mn 0s
Bit depth                                : 24 bits
Title                                    : Sound
Audio #5
Format                                   : PCM
Duration                                 : 1mn 0s
Bit depth                                : 24 bits
Title                                    : Sound
Audio #6
Format                                   : PCM
Duration                                 : 1mn 0s
Bit depth                                : 24 bits
Title                                    : Sound
Audio #7
Format                                   : PCM
Duration                                 : 1mn 0s
Bit depth                                : 24 bits
Title                                    : Sound
Audio #8
Format                                   : PCM
Duration                                 : 1mn 0s
Bit depth                                : 24 bits
Title                                    : Sound
Other #1
Type                                     : Time code
Format                                   : MXF TC
Time code of first frame                 : 10:00:00:00
Time code settings                       : Material Package
Time code, striped                       : Yes
Other #2
Type                                     : Time code
Format                                   : MXF TC
Time code settings                       : Source Package
Other #3
Type                                     : Time code
Format                                   : SMPTE TC
Muxing mode                              : SDTI
-bephop
In the future I will look at the option to choose between one stream mixed audio and separate mono streams on all built in broadcast encoders. Thanks for notifying :-)
