mihai55
Posts: 3 Joined: Thu Sep 24, 2015 6:49 am
Post
by mihai55 » Thu Sep 24, 2015 6:52 am
Minor bug - Progress bar in Monitor window is always at 100%.
best regards and thanks for FFastrans!
mihai
Posts: 1704 Joined: Sat Feb 08, 2014 10:39 pm
Post
by admin » Mon Sep 28, 2015 8:02 am
Hi mihai,
I cannot recreate this bug and I've never seen it before. What does you workflow look like and what version of FFAStrans are you using?
EDIT: I have now been able to reproduce the bug and I will have a closer look at it.
mihai55
Post
by mihai55 » Thu Oct 01, 2015 9:23 am
Hi. Maybe I'm wrong but during conversion I expected that bar progress to be at, for example, 60% (see attached picture) not at 100% always.
Nothing important, just cosmetic
best regards,
mihai
FFAStrans v0.5.2, ffmpeg git-9e9d731 32/64-bit Static, Win7
Post
by admin » Thu Oct 01, 2015 6:32 pm
Oh, I think I may have misunderstood you. The progress bar is only the total progress, and should only reach 100% when on the last processor. The progress for each processor is only displayed under the "Status" column.
However, I HAVE found a bug in the total progress bar but I'm not sure if that is what you're seeing.
