Quicktime Sources
fabrice
Quicktime Sources
Post by fabrice »
Dear Everyone,
I build a 1st simple workflow to export separately the audio of a quicktime file and encode 1 resulting audio with resized video.
BUT the process never start as it doesn't see any media in my source quicktime file with or without an AV/Decoder... any idea ?
Re: Quicktime Sources
Hi fabrice and thank you for using FFAStrans :-)
Do you get any error mesages in the status monitor? Are you using a "Folder"-monitor node or are you just submitting files manually?
fabrice
Post by fabrice »
Hi Steipal.
Firstly I would like to thank you for the work you've done here !
I found the way for the file to be seen by the watch folder now.
Actually I need to drop quicktime files with multiple 24bits or 16bits audio tracks (depending the sources) and export different files (audio only) with different channels I'd like to remap. I would like to avoid to convert 24bits tracks to 16 bits to achieve the process. I probably misuse the A/V Decoder...
I have no error messages but I can't find the way to have quicktime audio only files or multitrack wav files.
Fabrice
